Cosmick Posted June 19, 2013 Posted June 19, 2013 If you have been looking at getting a HD Cam for the Aircraft, consider this especially if you have an open cockpit or like BIG sunglasses .................... http://www.zealhd.com/ 1
bull Posted June 19, 2013 Posted June 19, 2013 or-even-better-with-3-hours-recording-and-also-11-hours-motion-detect-security-feature-and-high-quality-imagery-and-with-a-bit-of-duct-tape-you-can-mount-it-anywhere-for-different-aspects,i-use-one-for-r/c-model-aerial-videos..................................................................................................... HD Wing Camera 1280x720p 30fps 5MP CMOS This handy pocket camera offers stunning HD quality video in a compact and light weight package. With support for up to a 32gb Transflash card (Micro SD) you will be able to shoot hours of HD 720p footage. The built in 850mAh Lipoly battery provides up to 3 hours of recording time. This camera is the perfect companion to your FPV system, allowing you to install a second camera (other than your actual FPV camera) to capture your flights in 720p HD without adding a large weight penalty to your existing FPV platform. Even if your not into FPV this tiny HD camera is great for just about any model. Strap it to your car, heli or plane and record all the action to share with your friends in HD quality. Specs:120 degree wide-angle HD camera lens, 5 Megapixels COMS sensor Video resolution: 1280x720p 30fpsSelectable video quality: Superior/Standard/economicUnique motion-detect recording function Selectable motion-detect recording time: 10sec, 1min, 5min, 10minUnique loop recording function Photo resolution: 2560x1920 JPGBuilt-in 850mAh Lipoly battery provides up to 3 hours of recording Vibration alert support (Vibrates to confirm functions) Memory slot: Transflash (Micro SD) support up to 32 GB Size: 74mm x 28mm x 15mmWeight: 29.4gPC camera function TV-OUT mode for Video play back and Funtion setup TV-OUT modes Supports PAL/NTSC USB2.0 Includes:Camera Unit USB cable AV cable PRODUCT ID: A-CAM This product available from a warehouse near you! 125g 10+ Buy 1 Buy 2 Buy 3 Buy 4 Buy 5 Buy 6 Buy 7 Buy 8 Buy 9 Buy 10 Buy 11 Buy 12 Buy 13 Buy 14 Buy 15 Buy 16 Buy 17 Buy 18 Buy 19 Buy 20 Buy 21 Buy 22 Buy 23 Buy 24 Buy 25 Buy 26 Buy 27 Buy 28 Buy 29 Buy 30 Buy 31 Buy 32 Buy 33 Buy 34 Buy 35 Buy 36 Buy 37 Buy 38 Buy 39 Buy 40 Buy 41 Buy 42 Buy 43 Buy 44 Buy 45 Buy 46 Buy 47 Buy 48 Buy 49 Buy 50 Buy 51 Buy 52 Buy 53 Buy 54 Buy 55 Buy 56 Buy 57 Buy 58 Buy 59 Buy 60 Buy 61 Buy 62 Buy 63 Buy 64 Buy 65 Buy 66 Buy 67 Buy 68 Buy 69 Buy 70 Buy 71 Buy 72 Buy 73 Buy 74 Buy 75 Buy 76 Buy 77 Buy 78 Buy 79 Buy 80 Buy 81 Buy 82 Buy 83 Buy 84 Buy 85 Buy 86 Buy 87 Buy 88 Buy 89 Buy 90 Buy 91 Buy 92 Buy 93 Buy 94 Buy 95 Buy 96 Buy 97 Buy 98 Buy 99 Buy 100 $37.18
