Robert Posted June 1, 2013 Posted June 1, 2013 Hi all I am sick of the doors not staying open and thinking its time for new gas struts any advise on what ones to replace them with ????
Patrick Normoyle Posted June 1, 2013 Posted June 1, 2013 You can get them custom made here in SA about $30 each. If you have the old ones, he can make them the same length with the same fittings, measure the force rating and make the new ones slightly stronger. He did a set for me for my drifter canopy and they are really good. 1
Patrick Normoyle Posted June 1, 2013 Posted June 1, 2013 Strut Re-gas SA Rob Lowe 131, Augusta St., Glenelg East SA 5045 Ph/Fax: 08 8295 5596 Email Rob, from Strut re-gas SA
Robert Posted June 4, 2013 Author Posted June 4, 2013 Thanks for the info Patrick Will get in touch with them
Graham Pukallus Posted June 4, 2013 Posted June 4, 2013 Ditto. Just got mine regased at out local Caboolture Strut Re-Gas near airfield for $15.00 took 10 mins. Graham
rankamateur Posted June 4, 2013 Posted June 4, 2013 Do they drill a hole or uncrimp the end cap to regas a strut? Do they look any different after refurbishment?
Patrick Normoyle Posted June 4, 2013 Posted June 4, 2013 They can only add gas to the strut, and can usually only a few times, they drill a hole and seal it with solder I think.
Graham Pukallus Posted June 5, 2013 Posted June 5, 2013 No, they removed the small end attachment fitting and placed it into a pressure chamber and re pressurised the init to the original value and checked unit on a mechanical tester after replacing the end fitting. All ready to reinstall into Savannah door. They quoted approx $30 .00 for a new item. If you need assistance pm me and I can either take your unit to them or purchase a new strut for you. Their contact no is 07-54281006. Regards Graham 1
rankamateur Posted June 5, 2013 Posted June 5, 2013 So they blow the gas in past the seal, wouldn't work if that was the same seal that let the initial charge go then. 1
Graham Pukallus Posted June 5, 2013 Posted June 5, 2013 The strut was installed incorrectly by original builder 4 years ago eg main strut body to the bottom. I was told that you normally get a few recharges before the strut seals have had it if installed correctly. The pressure check was ok and I suppose the worst case scenario will be that I will need to buy a new item for $30.00. Will keep you posted.
