Can anyone tell me if the temp of the 2 stroke oil entering the engine will make any difference to performance. This is on a 582.
What do u mean are u premix or auto lube ?
The prelude system works at normal temp No heating required
Premix just mix oil in fuel ....
Good weather now Doug, have you picked up your aircraft yet?
No mate have to head south too a Ulysses AGM at marybough in the morning will be there till next
Sunday. Then if the weather permits will be heading north to pick up the plane . On Monday / Tuesday.
Guest Maj Millard
Doug, Start of good weather just around the corner and Old Station bit more than a month away, you need to get some NM under your belt in that bird.......Maj....poking.gif.62337b1540bd66201712a53e2664c9b4.gif
Guest Maj Millard
Timbgy, In answer to your question...no shouldn't make a hell of a lot of difference except if it was real cold, which could thicken it and cause it not to flow adequetly in an auto-lube set-up.....................Maj...024_cool.gif.7a88a3168ebd868f5549631161e2b369.gif
