Navy
On a carrier, the Naval Aviator looks over at the Catapult Officer
("Shooter") who gives the run up engines signal by rotating his finger
above his head. The pilot pushes the throttle forward, verifies all flight
controls are operational, checks all gauges, and gives the Cat officer a
brisk salute, continuing the Navy/Marine tradition of asking permission to
leave the ship. The Cat officer drops to one knee while swooping his arm
forward and pointing down deck, granting that permission. The pilot is
immediately catapulted and becomes airborne.
Army
If you've ever seen an Army helicopter pilot preparing for takeoff, you
will note that the pilot gives the ground guy a thumbs up before he is
given hover and takeoff signals. There are two theories about the origin
of this gesture. One is that it is to show that the pilot has identified
which of his fingers is the thumb so that he will be able to properly
operate his controls. The most compelling theory says that this is to show
the ground crewman that the pilot indeed knows which direction is up.
Air Force
We've all seen Air Force pilots at the air force base look up just before
taxiing for takeoff and the ground crew waits until the pilot's thumb is
sticking straight up. The crew chief then confirms that he sees the thumb,
salutes, and the Air Force pilot then takes off. This time-tested
tradition is the last link in the Air Force safety net to confirm that the
pilot does not have his thumb up his ass.
