Guest GraemeM
Can someone help me out please.
What is the minimum size battery in CCA that is required to reliably start a 582?
I don;t want to carry more than I need.
Graeme.
What size cable will you use and how close to the starter will the battery be? Do you want a battery that can start the motor in winter as well as summer? What if the engine is a bit hard to start? Would it be ok then to require a jump start from an external battery?
There's not a really simple answer
Can someone help me out please.What is the minimum size battery in CCA that is required to reliably start a 582?
Graeme.
check Lipo motorcycle battery on ebay very light ,many cca avaliable bit expensive but if weight is critical these save several kilos over equivelant AGM batteries
Mick
I use a 17aH SLA battery from supercheap auto. Lasts about 4 yrs. No dramas to date (6yrs), I am on my second one.
Guest GraemeM
What size cable will you use and how close to the starter will the battery be? Do you want a battery that can start the motor in winter as well as summer? What if the engine is a bit hard to start? Would it be ok then to require a jump start from an external battery?There's not a really simple answer
Good questions.
No cable size as yet, any suggestions?
Distance from battery to starter is no more than 1metre.
I live in North Qld, it is always summer.
If my engine becomes hard to start then it needs some maintenance.
Pud is using a battery at 220cca, anybody successfully using any smaller?
Graeme.
Munro the 680 od, kicks over the 912/914 without too much effort, so considering that you might be able to get away with as little as 150cca after all it is only a mossy smoke maker.. :)
Have a look at FULLRIVER batteries. you certainly wont want bigger than the PC625 equivalent (starts my 0-200 comfortably) I bought one recently and used it to start my 4 litre V8 quite easily ($100) much to the amusement of the mechanics at Toyota
