Admin Posted June 24, 2012 Posted June 24, 2012 Hi All I have added some extra formatting options for you to be able to use in your posts if you find you would like to enhance your posts. The formatting uses what is called "BBcode" and all the different BBcodes you can use in your posts can be found under the Help menu -> BB Codes: http://www.recreationalflying.com/help/bb-codes 1. The ability to float an attached image to either the left or right of your post and have your post text wrap around the image: [floatl][/floatl]Lorem Ipsum is simply dummy text of the printing and typesetting industry. Lorem Ipsum has been the industry's standard dummy text ever since the 1500s, when an unknown printer took a galley of type and scrambled it to make a type specimen book. It has survived not only five centuries, but also the leap into electronic typesetting, remaining essentially unchanged. It was popularised in the 1960s with the release of Letraset sheets containing Lorem Ipsum passages, and more recently with desktop publishing software like Aldus PageMaker including versions of Lorem Ipsum. [floatr][/floatr]Lorem Ipsum is simply dummy text of the printing and typesetting industry. Lorem Ipsum has been the industry's standard dummy text ever since the 1500s, when an unknown printer took a galley of type and scrambled it to make a type specimen book. It has survived not only five centuries, but also the leap into electronic typesetting, remaining essentially unchanged. It was popularised in the 1960s with the release of Letraset sheets containing Lorem Ipsum passages, and more recently with desktop publishing software like Aldus PageMaker including versions of Lorem Ipsum. 2. The Spoiler BBcode that allows you if say for example you ask a question and you want to hide the answer until a user wants to know it you can use the Spoiler tag: "If an aircraft was on a conveyor belt, would it be able to take off?" [spoiler=SPOILER!]The answer my friend, is blowing in the wind... I will be adding many more little formatting tools (BBcodes) as we go so to find out what is available for you to spruce up your posts a little, if you feel the urge to, then keep an eye on the BBcodes list in the site "Help" section.
