Case Posted May 28, 2006 Posted May 28, 2006 Hi All, Can anyone tell what exactly is the difference between certified and uncertified aircraft engines ?. Do certified engines have different (better quality) parts ? Regards Case
Guest micgrace Posted May 28, 2006 Posted May 28, 2006 Hi, Certified means tested to a design standard eg. 101.55 i.e. test run for various times at various loadings to strict standards. Look 101.55 up (not the only standard) but the one most applicable to RAA. Uncertified does not mean substandard parts. All certified engines started as uncertified at some point till testing and other paperwork requirements were passed. Your you beut certified engine rapidly becomes uncertified the second you change a plug or oil (in GA anyway and God help you if you do) for our purposes it was certified, but to be brought back to certified status it's off to the LAME with fistfulls of dollars. IFF they'll do it. It's actually a little more complex than that, I hope that helps somewhat Micgrace
Case Posted May 28, 2006 Author Posted May 28, 2006 Thanks Michael, That is clear enough. regards Case
Guest Fred Bear Posted May 28, 2006 Posted May 28, 2006 Depending on the engine manufacturer, certified aircraft engines can also be built to more exacting tolerances. Certified also equals expensive. A good example of this is the Rotax 912 and Rotas 912A, with the latter being the certified version and far more expensive. Aside from price and paperwork the engines are 99% the same, however the certified version is more likely to have been checked and re-checked. It's a bit of a catch 22 however, because it's not like an engine might be a little dodgey, so they just call that one a non-certified model, it's more about processes, quality assurance, paperwork and liability. Hope that muddles things for you enough. Clem.
Guest micgrace Posted May 28, 2006 Posted May 28, 2006 The processes are mainly the same if certified or uncertified. Mainly paying for the legal liability (plus testing etc) if certified. If uncertified you get to carry the liability not the company. Due to small production runs a manufacturer is hardly likely to have any changes in production between uncertified/certified. This simply doesn't make economic sense. Micgrace
