eastmeg2 Posted April 30, 2007 Posted April 30, 2007 Hi All, I've heard that Paul Haines hangar at Albion Park (Wollongong airport) burned down yesterday morning with numerous trikes and a few very slick ultralights all going up in smoke. Anyone got more news ???
slartibartfast Posted April 30, 2007 Posted April 30, 2007 From ABC Illawarra News: Airport blaze not considered suspicious Monday, 30 April 2007. 12:28 (AEST)Monday, 30 April 2007. 12:28 (ACST)Monday, 30 April 2007. 028 (AWST) Police say a fire which has destroyed two ultralight aircraft and damaged several others at the Illawarra Regional Airport does not appear to be suspicious. Police and fire brigade units were called to the fire in a hangar at the northern end of the airport at Albion Park shortly before 7:30am AEST yesterday. On arrival, flames could be seen coming from the skylight of the building. Firefighters gained access to the building and took more than an hour to extinguish the blaze. There has been no estimation of damage yet.
Ultralights Posted April 30, 2007 Posted April 30, 2007 sad indeed... if your aircraft is lost in a hangar fire, is it covered by the hangars insurance or your own?
bushpilot Posted May 1, 2007 Posted May 1, 2007 Isn't Paul Haines also very ill?? If I have that right then he is having a real bad run of luck...
Thruster87 Posted May 4, 2007 Posted May 4, 2007 Seems one of the trikes had a bar drop/fall and it made contact with the battery terminals and short circuit occurred.Hopefully not a on going problem with the design. Two planes burnt and a couple of others had the Dacron melt including the sky lights on the hangar.
eastmeg2 Posted May 4, 2007 Author Posted May 4, 2007 Not as bad as was initially thought then. If it's what I've heard, the trike manufacturer had just issued a notice a few days earlier advising owners to replace the restraining cable for that bar with a shorter version that prevents it from being able to reach the battery.
Guest iraj Posted May 4, 2007 Posted May 4, 2007 I know poul & also I flew his xt few times. I hope that he is ok.
AzharFly Posted May 5, 2007 Posted May 5, 2007 Trike bar Hi, Just wondering which 'bar' fell onto the battery terminals? This happened when no-one was present right? Azhar
Thruster87 Posted May 5, 2007 Posted May 5, 2007 It seems it was the T-Bar type handle on the post attached via a safety cable. A mod which needs to be done is to shorten it, so if it comes loose it cannot reach the positive battery terminal and short to frame and the cable melt the fuel tank. [Airborne Trikes]
Guest Crezzi Posted May 7, 2007 Posted May 7, 2007 link to the Airborne Service Bulletin http://www.airborne.com.au/images/aw...6%20Issue1.pdf
Dieselten Posted May 21, 2007 Posted May 21, 2007 Here is the gen (I own one of the trikes in that hangar):- Airborne Edge-XT - base totally destroyed Pegasus Quantum - base totally destroyed Edge-X 582 base - severe fire damage Edge-X 582 base - moderate fire damage Edge-X 582 base - moderate fire damage Edge-X 503 base - slight damage Streak Mk1 wing - written off Wizard Mk1 wing - written off Jabiru SP470 - probable write-off, both wings u/s, fuselage heat-affected Grumman Cougar - paint smoke and soot-damaged Super Ximango motorglider - slight smoke damage Globe Swift - minor smoke damage hangar roof - Alsynite burnt out, structural members distorted, roof cladding warped. The T-handle that locks the mast on the Edge-XT was not, repeat NOT, the cause of the fire. There are no suspicious circumstances. The definitive cause will probably be determined by forensic investigator and possible coronial enquiry. Investigations are ongoing. Sydney Microlight Centre are back training again with one machine (Edge-X, Mk2 Wizard).
Dieselten Posted October 10, 2007 Posted October 10, 2007 Nothing definitive as yet, still in the hands of the forensic investigator and insurance companies.
airborne Posted April 5, 2008 Posted April 5, 2008 has there been anything definitive on the cause of the fire yet?? also any one know how paul is donig
Dieselten Posted April 5, 2008 Posted April 5, 2008 The Wollongong Coroner has requested a report on the fire following Police investigations. With deep regret and profound sadness I have to advise that Paul Haines passed away on the morning of Friday 28th March 2008, peacefully, at his home in Stanwell Park. His funeral will be held at Parsons Funeral Home, Bulli, starting 12 noon on Monday 7th April. Afterwards a celebration of his life will be held at The Kiosk, Stanwell Park. Apologies for the late notice, I have been away for a fortnight and just got back.
