This one grabbed my attention when visiting HARS a while back. From a P&W R1830 powering one of their DC3's
Sure it's a Cont IO-540? If it's Continetal it would have to be 520, Lycoming is 540 is it not? 001_smile.gif.2cb759f06c4678ed4757932a99c02fa0.gif
Just the images you dont want running through your mind when your flying a Titan!
Thomo
I thought the LAME said it was a Continetal when I spoke to him. Whatever Barrons run?
Still not pretty whatever the make.
Frank
No worries Frank, wasn't concerned just curious myself.
Seems it depends on the age, and model of Baron... as they started off with Cont. 470, then 520, then Lycoming 540 etc... so we'll have to just contend ourselves with that! 010_chuffed.gif.c2575b31dcd1e7cce10574d86ccb2d9d.gif
Guest Maj Millard
The Continentals are pretty good at popping heads off, especially in C210s for some reason. When working on Cessna ag-planes a few years back, we would change five Continental cylinders to one Lycoming, on average. It was not uncommon to change at least one, and possibly more, each 100 hrly, on the ag-planes. Remember these are working aircraft which do fully loaded takeoffs all their life, so a 100 hours for them, is not like a 100 hours for you and I.
We recently popped a cylinder-head off one of the Beavers, but you only loose 1/9th the power. A water landing at Shute Harbour, a quick cylinder change and back in service. The R985 Beaver engines come out of Tulsa Ok, with redone cylinders. There are no new cylinders available anymore. They do Xray and ultrasound them to look for internal defects, but who really knows what those cylinders have been through. We had another from them under warranty within a week.
The IO540s which I suppect Franks' cylinder is from, are also mostly fitted to working aircraft also, E: Barons, Chieftans, islanders etc. and most would be running redone cylinders also.
below are some photos of the Beaver cylinder that failed. It's finished it's aviation career and the barrel is now in the hangar toilet as a brush holder !! The heads on the beaver cylinders are actually screwed onto the cylinder barrel whilst heated. It is ment to be there for it's life. The lycomings and Continentals may be one piece castings that are then machined....................................Maj...024_cool.gif.7a88a3168ebd868f5549631161e2b369.gif
338756190_BurdekinFlightwithKelly015.thumb.jpg.fdc3e6eb6cb305ff63f36277f1caea1a.jpg ...............................................Maj
Nah......Continentals and Lycomings are head and barrel screwed together...Heads are alloy and barrels steel!
Guest Maj Millard
Ok, that's right yes.....................................................Maj...024_cool.gif.7a88a3168ebd868f5549631161e2b369.gif
Hi all, Barons would run the 470s or the 520s......Continental engines. A lot has to do with cylinders being recycled at overhaul instead of being trashed, and pilot technique as far as rapid or shock cooling on desent......and then theres' just old age...bit like Maj Millard poke_tongue_out.gif.5a7d1a1d57bd049bd5fb0f49bf1777a8.gif
