Hi Guys and Gulls ,
Is there any designers out there who has a little time to give me some guidence ? I am a pilot with a lot of ideas , but need someone to wack me against the head and direct me in the right direction with my basic designs .I am busy at this moment designing a footlaunchable glider , but need someone to work out the CG , stall speed of the craft before I start construction .If anyone is willing to lend a hand , please contact me . [email protected]
Best regarts and a happy flying new year
Deon
I think a lot more info will be required before anyone can even hazard a guess.
Hi Jake and Yenn ,
Not as fancy as the attachment .I am planing to build a Primary footlaunchable glider . That is the plan , but because I use only a short wingspan and if the take-off speed will be to high to footlaunch then I will use it with winch , tow or bungy launch .Safety is my main concern and performance come second . I like old design aircraft and has use the Scud 1 sailplane of I think 1920 as a model to start designing my glider . The specs. of the glider is as follow . Wingspan : 8,40 m , Chord : 1,20 m ( constant chord ) , Lenght : 4 m , Empty weight : 40 kg , Pilot weight : 77 kg , Horizontal stab . span : 2,44 m . Aitfoil : Wortmann FX 63 - 137 . The rudder and stabalizers is interchanchable and the same dimentions .At this moment I need to know the stall speed to deside if I can make it a footlaunch or just a primary glider .If needed I can post the basic plan with measuremants .
Thank you for your responce
Best regarts
Deon
More like something of this nature perhaps.
EDIT forgot to add, don't try designing your own unless you're prepared to do a lot of studying before hand.
Thanks for the advice everyone .I did study the footlaunch gliders for some time . I did fly hanggliders for many years , chanched to paragliders , fly and build ultralights and light planes , have a sailplane lisence and has a Airforce back ground .I have study the Swift , ULF1 , Goat , Bug and Pig airchairs .I build my first hangglider when I was 9 years old from a photo I have seen in a mag .Build several Rogallos and other hanggliders , design and build a few trikes ,build a Benson gyroglider and later motorized it .build a Heath Super Parasol , build a Grunau Baby glider from 3-view drawings , I like building and flying and would like to build this glider I describe to you .Most of the aircraft I have build was from plans , only the trikes and hanggliders was my own design .I think I have enought knowledge to build it without help , but it is easier and cheeper to ask profesional people to help . I can build it , fly it in ground effect , move the wing or add weight if needed , but as I say it will save me a lot if one could work it out on paper before building it .I have build a scale model , but when I try to put it on this site it said the files is to big ? It is only 3 pictures . Is there another way to send it that you guys can see it ?
cheers
Deon
Hi Guys and Gulls ,Is there any designers out there who has a little time to give me some guidence ? I am a pilot with a lot of ideas , but need someone to wack me against the head and direct me in the right direction with my basic designs .I am busy at this moment designing a footlaunchable glider , but need someone to work out the CG , stall speed of the craft before I start construction .If anyone is willing to lend a hand , please contact me . [email protected]
Deon
I have not played with this so can offer no advice but try this link. It might provide a solution.
www.flight-dynamic-simulator.de/
Hi Deon, have you checked out the BUG (basic ultralight glider), GOAT (no idea) and PIG (primary instruction glider) gliders over here:
http://m-sandlin.info/
They are all extremely basic and often foot launched.
Yes ,I got plans for all of Mikes gliders . Because I fly sailplanes , I like the more clasic lines of a sailplane and also like the portability of a hangglider .My design is build of wood and fabric , it has a very streamlined fuselage with high wing and all moving tail feathers .The Sadlin airchairs is more bulky , alumenium and fabric . His designs fill a gap in aviation but I like a more sailplane look glider . I tried again to post a photo of my scale model , but the site said the file is to big .
Deon
Deon, dowload and install 'VSO Image resizer' , set to 800 x 600 and you should be ready to go. What you get in the download is a trial version but you can use it over and over again. I've had it for a couple of years now. Always make copies of your originals (option)
Hi Guys ,
Thank you for all the input .I have sorted the problem out and do not need more help in this case . I am now ready for the next step , starting collecting material for construction .
Deon
