Jabiru propeller holes pattern
Does anybody knows the Jabiru propeller holes pattern? (the diameters of center holes, diameter of bolt holes and the bolt holes pattern on PCD)
Thanks
Harris:puzzled:
Does anybody knows the Jabiru propeller holes pattern? (the diameters of center holes, diameter of bolt holes and the bolt holes pattern on PCD)Thanks
Harris:puzzled:
I can't help you, but when you get the numbers, ensure it's for the correct engine. I was sent a plate which was too large for my 2.2L, so I presume it was meant for a 3.3L.
Thank you for your reply. yes you are right, J2200 flange is different from that of J3300, but I can't find out the flange drawing on Jabiru Website.
My friend is making a wood propeller for J2200 engine, 60"x42", but don't know the holes information.
Harris
