Guest rocketdriver Posted September 2, 2011 Posted September 2, 2011 Great photography ... wonder what they used for a camera ship?
Owi Posted September 2, 2011 Posted September 2, 2011 Excellent video. Really enjoyed that one. It might be stating the obvious but one also needs to ensure that the aircraft is capable of sustained inverted flight before practicing this.
naremman Posted September 2, 2011 Posted September 2, 2011 [medio=full]50[/medio] Great footage, but hope it form the basis of what not to do in an RAA aircraft. When the RAAF took the CT4 on board it was not too long before a restriction on convential spinning came into effect. That restriction did not preclude inverted spinning, so guesss what happened?
Bandit12 Posted September 2, 2011 Posted September 2, 2011 The CT4 also gets into an inverted spin really easily. Stall turning requires nearly full forward stick and opposite aileron otherwise it rolls and goes straight into an inverted spin.....
Neil_S Posted September 3, 2011 Posted September 3, 2011 Hey Winsor, Great video - very interesting. Cheers Neil
Spin Posted September 3, 2011 Posted September 3, 2011 [medio=full]50[/medio] Personally I find that if you cut off his alcohol supply and gently roll him over, he mostly recovers on his own.
Suitman Posted September 4, 2011 Posted September 4, 2011 Personally I find that if you cut off his alcohol supply and gently roll him over, he mostly recovers on his own. - From Spin's personal operating manual, chapter 6 - Recovery 1
djpacro Posted September 6, 2011 Posted September 6, 2011 When the RAAF took the CT4 on board it was not too long before a restriction on convential spinning came into effect. That restriction did not preclude inverted spinning, so guesss what happened? The RAAF spin recovery technique could lead to very long recovery times from upright spins (the flat mode). Offhand I can't remember what the RAAF report said about inverted spins.The NZ civil flight manual for the aeroplane has a different spin recovery technique which will achieve recovery within one and a half turns as required by FAR 23. No issue with recovery times from an inverted spin and it is approved for inverted spins however personally I wouldn't do it without inverted systems on the engine. Some types go into an inverted spin quite easily from a stall turn or botched roll off the top. Interestingly, I often have instructor trainees brief me on the need for opposite aileron in a stall turn then I go and demonstrate a neat one with the stick held steady dead centre.
