Ok......what,s this "cold start kit" you mention.
  • Replies 52
It's a clever replacement for the LH coil, Russ. While the starter is energised the secondary winding cuts in and is triggered by a hall-effect sensor a few degrees after the coil. It produces a retarded spark at very low revs, only when cranking. Just what you need for a cold Jab with crook battery.
I'll be putting one of these on my UL 450 project as it has an early solid lifter 2200 with a smaller starter motor. The kit should negate any shortcomings of the smaller starter motor. Laurie
