ADVISORY ENGINE BULLETIN #19
– June 2011
To all Dealers and Maintenance Persons
CONTENTS
1 HYDRAULIC ENGINES (PUSHRODS)
Inside a hydraulic valve lifter there is a piston which “floats” on oil with its position
regulated by springs, valves and oil pressure. The way it moves relative to the
lifter body is what allows the hydraulic lifter to automatically adjust for valve train
variation and maintain the correct valve seating parameters. The piston has a
limited range of movement however – and if it reaches the limit of its travel valve
control issues will result.
A number of factors such as a recessed head/cylinder spigot, a very deeply cut
valve seat and a crankcase which has been surfaced/line bored (reduced width)
can affect the position of the piston within the hydraulic valve lifters – bringing it
to the limit of its travel.
In cases where the lifter travel has all been used there are a number of different
solutions –
i. The standard pushrod length is currently 216mm. A 215mm rod is available
as a spare part to allow for the effects noted above.
ii. If the engine is currently equipped with 107.0mm long cylinders fitting a
0.5mm shim (recommended to improve the engine’s tolerance of various
fuels) will also help counteract the valve lifter issues. Note that due to the
gear ratio of the valve rocker increasing the length of the cylinder has the
effect of moving the piston within the lifter by about 0.6 – 0.7mm.
iii. Replacing worn valves and rocker bushes can also help.
2 NEW PLENIUM CHAMBER (INTAKE)
The shape of the induction chamber for 3300 engines was changed from S/N
2331. The new chamber has a different shape, different internal diffusers and
uses some new-shape induction pipes. The effect of this chamber is to create a
more even mixture distribution between the cylinders. The result is that the
difference between the hottest and the coldest EGTs are reduced.
3 CYLINDER BASE NUTS
Jabiru Service Bulletin JSB031 was recently released to address issues with
cracking of the through-bolts which hold the engine halves together. This
bulletin affects the majority of the engine fleet and operators & maintainers are
urged to familiarise themselves with its content as soon as possible.
With regard to this issue, engines overhauled must now use the new 3/8” nuts
(shaped in 12 points) instead of the previous MS21042-type nuts.
The torque of the cylinder base nuts remains set at 30lb.ft and through bolts
have been lengthened to take advantage of the increased number of threads on
the nut. Because they have no “deformity” for locking they must be locked with
620 Loctite on installation. Our website has the 3 documents available which are
relevant to this issue: the Service Bulletin, Bulletin Procedure for carrying out the
work called for in the bulletin and a procedure for chamfering the base of the
nuts to ensure they do not bind on the base radius of the cylinder.
New production engines are now using either the 12-point 3/8” nuts or a custommade
stainless steel 7/16” nut. Note that the use of the 7/16” hardware has
forced changes to cylinders, crankcases and crankcase dowels meaning that
7/16” bolts cannot be easily used in an older engine.
4 FLYWHEELS
In 3300 engines the inner part of the flywheel “starfish” has been altered to give
a reduced advance on spark timing (not cam timing). Spark advance is now set
at 20° BTDC. This has been introduced on 3300 engines from S/N 2391.
This change has had negligible effect on power output but makes the engine
significantly more tolerant of poor fuels and other factors which can lead to
detonation.
5 CRANKCASE DOWELS
The fit of the dowels which locate the two halves of the crankcase has been
identified as a significant contributor to structural issues with the crankcase
– be
it fretting or damage to the case hardware. Accordingly new “oversize”
crankcase joining dowels have been produced and must be used at overhaul to
maintain a “snug” fit of case halves.
These dowels now come as:
- standard @ 12.501 – 12.512
- 1 dot @ 12.512 – 12.523
- 2 dot @ 12.523 – 12.534
- 3 dot @ 12.534 – 12.545
The identifier “dot” is on the mid section of the dowel. This means careful
measurement of case when overhauling to fit all “snug” dowels.
When overhauling it is necessary to assemble the case (potentially several
times) to check bearing clearances. During this process it is recommended that
older dowels are used to simplify repeated assembly and disassembly. These
must then be replaced with tight new dowels at final assembly.
The fit of these dowels is critical to the structure of the engine and must be
checked carefully whenever cases are split.
6 THROUGH BOLTS
See Service Bulletin JSB031-1 on through bolts requirements, depending on
engine lift nuts changed and or through bolts at nominated time in service or time
since overhaul. Also refer to the companion documents for workshop
procedures for carrying out the required work.
7 OVERHAUL MANUAL
This document is available on the Jabiru web page. It will be regularly updated –
several of the points discussed in this bulletin will be detailed in the next revision
of the manual.
8 ENGINE MANUALS
Because now a detailed overhaul manual is available it was decided that
duplication of much information on engine disassembly and assembly could be
therefore omitted from these manuals (4 and 6 cylinder).
The 8 cylinder manual remains the name. All the necessary information could be
sought from the one overhaul manual.
9 SERVICE BULLETIN - FLYWHEEL
All owners and service persons should be aware that all Jabiru Engines are
currently subject to periodic checks of the flywheel installation. JSB012-2 refers
– please read it carefully and it will clarify what the requirements are for each
given engine configuration.
10 CLIMB OUT SPEEDS
There appears confusion on best climb out speeds. Manual specifications for
best rate of climb for J160 and J230 is 68 and 75 knots respectively.
This means this air speed will give the best chance of clearing obstacles if the
need arises. However the rate of climb for best engine management has been
largely left to operators.
The quickest way between two sets of traffic lights is to floor the accelerator and
race the engine
– but it’s not the way most of us do things because we
understand that driving that way will use more fuel and wear the engine out
faster. Similar arguments apply to climb speeds with a Jabiru Engine.
The 4 cylinder engine will look after you better with better air/oil cooling if
climbed around 80 knots while the 6 cylinder will think highly of you at a 90 knot
climb or above. If flying a J430/J450, climb speeds for load will differ especially
according to load. Once heading to that cross country destination cruise climb at
elevated speeds (shallow angle of climb) contributes to good engine
management.
At these higher speeds not only is there more air available to cool the engine but
the RPM is higher, allowing the engine to rev more instead of “lugging”. This
significantly reduces the stress on the engine and makes it less likely to suffer
detonation or other long-term maintenance issues.
Also see JSB031-1 at Section 3.3 on climb out speeds.
Training organisations with limited runway distances will need to use best rate of
climb initially but then can accept a higher air speed / lower rate of climb when
safely into the circuit. When operated this way engines with the fine finned heads
are difficult to elevate the heat range.
There also appears much debate on static or rolling RPM. Manuals state around
2800 RPM static. This was written mainly with the 2200 engine in mind – 3300
figures are slightly different (and limits will be adjusted in the next manual
revisions). To clarify, a new engine (6 cyl) driving a 60x53 Jabiru prop in a J230,
rolling in take off mode will show 2700 or there abouts. Once clear of ground
and in clean configuration, 90 knots will give a good 2800 RPM or better.
Manuals recommend RPM area guide especially for non Jabiru prop fit ups.
Secondly, if static or rolling RPM is in the 2700-2800 range this is relevant to
carby tuning and directly related to cruise power at 75% power.
11 OPERATING RPM
Historically we have always recommended that operators allow their engine to
rev rather than lug. Done properly this approach works very well, however in
certain cases it can also be damaging as it has been over-simplified and does
not necessarily consider percentage power.
For example, consider a Jabiru J200 with a Jabiru engine, propeller and cowls.
In a full power, straight and level run at sea level this aircraft should reach
speeds in the 130 – 140 KIAS range and the engine will be revving to around
3100 – 3200RPM. In this aircraft – which is fairly sleek and fitted with a wellmatched
propeller – cruising at 2900 rpm is fine because it will be at a relatively
low power setting.
In comparison, the same engine and propeller could be fitted to a bush plane
with slats, flaperons, tundra tyres and the aerodynamics of a brick. In this case
the static RPM and RPM on take-off would be similar to the J200 – but flat out
straight and level at sea level the aircraft won’t do much more than 100 knots
and the engine will be stuck at about 2900 – 3000 RPM or less. In this case
trying to cruise the engine at 2900 RPM would be disastrous as it would be a
very high percentage power setting.
The above examples are deliberately extreme but their message can be applied
across all airframes and engine models.
In the near future we plan to publish limits for manifold pressure at given RPMs
the combination of MAP and RPM allowing the pilot to accurately know how what
percentage of their engine power they are using at any given time. However,
until that information becomes available operators must avoid over-simplifying
the “more RPM is better” rule.
12 RECENT CHANGES BY SERIAL NUMBER
3300 2200
Cylinder length increased to 107.50mm 2290 - 3443 -
Hollow pushrods/rockers 2210 - 3358 -
* Thicker walled crank gear 2310 - 3443 -
** 3300 engines only with 7/16” thickness through bolts 2391 -
Spark tuning change to 20
o
BTDC 2391 -
Longer through bolts and 12 point nuts 2371 - 2390 3483 - 3498
“Starfish” inner (steel) for flywheel attachment 1522 - 2732 -
New induction body (parallel sides) 2331 -
Note:
Thicker walled crank gear uses a narrower rear seal. O.D. of seal is the
same as original seals.
These engines have larger holes in cylinder bases to fit larger diameter though
bolts. 7/16” stainless nuts manufactured for Jabiru engine used on cylinder base.
Leith McLennan
JABIRU ENGINE DIVISION
