Guest thrasher
Military Wisdom I
"A slipping gear could let your M203 grenade launcher fire when you least
expect it. That would make you quite unpopular in what's left of your
unit."
- Army's magazine of preventive maintenance.
"Aim towards the Enemy."
- Instruction printed on US Rocket Launcher
"When the pin is pulled, Mr. Grenade is not our friend.
- U.S. Marine Corps
"Cluster bombing from B-52s are very, very accurate. The bombs are
guaranteed to always hit the ground."
- USAF Ammo Troop
"If the enemy is in range, so are you." - Infantry Journal
"It is generally inadvisable to eject directly over the area you just
bombed."
- U.S. Air Force Manual
"Try to look unimportant; they may be low on ammo."
- Infantry Journal
"You, you, and you ... Panic. The rest of you, come with me."
- U.S. Marine Corp Gunnery Sgt.
"Tracers work both ways."
- U.S. Army Ordnance
"Five second fuses only last three seconds."
- Infantry Journal
