pudestcon Posted February 18, 2011 Posted February 18, 2011 I'm trying to obtain some wing spar U brackets for a mates Gemini. These are the U brackets used to attach the spacer tubes between the trailing and leading edge spars. The photo attached here shows what is currently on the aircraft. These U brackets are not the approved type, having a straight, flat bearing edge to the spar, rather than a concaved surface to mate positively with the spar. The leading edge spar and trailing edge spar are of different diameter tube so the U brackets are different for both spars. I'd be very interested in talking to anyone who has some of these U brackets surplus to requirements that we can acquire. Thanks in advance for your help. Pud
Brownie Posted February 19, 2011 Posted February 19, 2011 Hi Pud I got some through wade air a couple of years ago he still might have some . You dont know where I could get some wing struts for my T300 do you . Thanks Brownie 1
pudestcon Posted February 19, 2011 Author Posted February 19, 2011 I'll give Wade a call, thanks guys. I don't know of any struts around the place Brownie, but if you do manage to get second hand ones just be careful that the cast alum connection fittings are sound. Check out the AN on them for details. Pud
pudestcon Posted February 22, 2011 Author Posted February 22, 2011 Check out the AN on them for details.Pud In actual fact it is not an AN but a UK mandatory permit directive. Go http://www.recreationalflying.com/showthread.php/104294-Thruster-wing-strut-attachments-UK-mandatory-permit-directive to check it out. Here is a better photo of the u brackets required. Wade is going to come back to me with a price. I am still interested if anyone has some lying around that they wouldn't mind getting rid of. Pud
pudestcon Posted February 27, 2011 Author Posted February 27, 2011 These are the brackets we require and the number of each type. Cheers, Pud
Brett Posted February 27, 2011 Posted February 27, 2011 What about something like this that is sometimes seen on microlights and handgliders ,,,,,, http://www.aircraftspruce.com/catalog/appages/type1saddles.php
pudestcon Posted February 28, 2011 Author Posted February 28, 2011 What about something like this that is sometimes seen on microlights and handgliders ,,,,,, http://www.aircraftspruce.com/catalog/appages/type1saddles.php Very interesting Brett, but maybe not quite what is needed in this situation. When I have a bit more time I'll check out that link more. Thanks, Pud
