Guest rocketdriver Posted November 21, 2010 Posted November 21, 2010 Has anyone got photos / info regarding succesful subaru motor cooling installations. I have just taken delivery from Canada of a KR2 with a Subaru motor which has a rather innefective looking radiator installation under the belly .... its parallel to the airflow mounted about 25mm off the belly skin ..... Cheers RD
Guest Baphomet Posted November 21, 2010 Posted November 21, 2010 It may be far more effective than it looks. My aircraft has a similar configuration, and it works very well. That layout has the advantage of a small frontal area, and as long as the ducting works, it should be fine. Baph
Guest rocketdriver Posted November 22, 2010 Posted November 22, 2010 Hi Dexter and Baph No ducting, just a sheet metal frame closed on the sides, open bottom, front and rear.. The water pipes run under the fuse to the radiator which is mounted about 25 mm off the skin and parallel to it. It would be nice to see a sketch / photo of the Avid installation and yours too Baph ...... Regards RD
bushcaddy105 Posted November 22, 2010 Posted November 22, 2010 I will take some photos of my Subaru setup (the computer seems to have swallowed the ones I thought I had) and pm them to you ASAP
Guest rocketdriver Posted November 22, 2010 Posted November 22, 2010 Thanks John ..look forward to seeing them and TIA!
Guest rocketdriver Posted January 24, 2011 Posted January 24, 2011 Thanks Dexter ....Very reassuring as it is very similar to my set up except possibly a bit more angled into the airstream than mine. We will see ...... I reckon I'm about 6 weeks from 1st engine run and taxiing tests ....
