Paul Willett Posted March 6, 2007 Author Posted March 6, 2007 Result: http://recreationalflying.com/forum/showpost.php?p=30116&postcount=8
timshel Posted October 4, 2007 Posted October 4, 2007 Hi paul, whathappened in the end - I was learning alot, but your result posting link was a dead link, whats the end of the story?
slartibartfast Posted October 4, 2007 Posted October 4, 2007 timshel - I think it was this thread. Installing an Odyssey 680 battery solved the issue and now she cranks like a Prime Minister. I've got one too. Ross
Paul Willett Posted October 5, 2007 Author Posted October 5, 2007 I think my thread link might have got deleted. Turns out it was not the battery at all, although the Odysey is just an amazing battery, very pleased I spent the $$$ to upgrade to this amount of power. The real cuplrit was a small amount of Inox spray that had leached in to the starter motor housing following an engine clean. This was causing a short and blowing the master fuse, as it is supposed to as a precaution. Following a strip down and clean of the starter motor housing it has started first time ever since. Another lesson learnt. (And no need to change the master fuse since - although I have learnt a very quick way to do it if anyone else has to.)
wanabigaplane Posted February 16, 2008 Posted February 16, 2008 Inox spray ? How could some Inox spray in the starter motor cause a problem? The liquid is an insulator, and a lubricant. Would it be more likely that in disassembly and reassembly you cleared a mechanical problem you were previously unaware of ?
Paul Willett Posted February 17, 2008 Author Posted February 17, 2008 The LAME working on it found a residue, which was causing the short - assumption on my part about it being INOX - but you are quite right about the qualities of INOX. Whatever it was no problems whatsoever since it was cleaned and refitted.
