  • 6 months later...
I think my thread link might have got deleted.
Turns out it was not the battery at all, although the Odysey is just an amazing battery, very pleased I spent the $$$ to upgrade to this amount of power.
The real cuplrit was a small amount of Inox spray that had leached in to the starter motor housing following an engine clean.
This was causing a short and blowing the master fuse, as it is supposed to as a precaution. Following a strip down and clean of the starter motor housing it has started first time ever since.
Another lesson learnt. (And no need to change the master fuse since - although I have learnt a very quick way to do it if anyone else has to.)
  • 4 months later...
Inox spray ?
How could some Inox spray in the starter motor cause a problem? The liquid is an insulator, and a lubricant. Would it be more likely that in disassembly and reassembly you cleared a mechanical problem you were previously unaware of ?
The LAME working on it found a residue, which was causing the short - assumption on my part about it being INOX - but you are quite right about the qualities of INOX.
Whatever it was no problems whatsoever since it was cleaned and refitted.
