I fly a Alpi Pioneer P300 with a Jabiru 3300A and have discovered a oil leak at the mechanical fuel pump. Suspect a distorted spacer block which looks to be a plastic or composite material. Has any body had a similar problem
Guest davidh10
Welcome P300NZ. I'm also sure you will find someone to help, but as this is an "introduce yourself" Forum, I suggest you post your question as a thread in the Jab Forum. More Jab owners will likely see it then.:)
Welcome P300NZ sorry can't help you with your problem. Are you from the North or South Island? Regards Sue
Hi Sue
I am based on an airstrip on the Coromandel peninsular in the North Island. It is a beach resort with a small permanent population.
