The following new and revised Service Instruction documents have been released by Rotax:
SI-912-010 R2,
SI-914-011 R2 - OIL CHANGE ON ROTAX ENGINE TYPE 912 AND 914 (SERIES)
SI-912-018,
SI-914-020 - PURGING OF LUBRICATION SYSTEM FOR ROTAX ENGINE TYPE 912 AND 914 (SERIES)
These new and revised service documents may be downloaded from www.rotax-owner.com
SI-912-010 R2 - http://www.rotax-owner.com/si_tb_info/getdoc.asp?USERID=byteboy&DOCID=SI-912-010&S_TYPE=NW
SI-914-011 R2 - http://www.rotax-owner.com/si_tb_info/getdoc.asp?USERID=byteboy&DOCID=SI-914-011&S_TYPE=NW
SI-912-018 - http://www.rotax-owner.com/si_tb_info/getdoc.asp?USERID=byteboy&DOCID=SI-912-018&S_TYPE=NW
SI-914-020 - http://www.rotax-owner.com/si_tb_info/getdoc.asp?USERID=byteboy&DOCID=SI-914-020&S_TYPE=NW
Regards
Dave
  • 10 years later...
Hi,
Just completing my 800hr operation and 5 year rubber replacement. Last time I did this I had easy access to a nice compressor with good regulator (to get the pressure down to below 15 psi) to do the PURGE.
Accessing a compressor is now more problematic SOooo I thought (dangerous) is there a way to ensure complete uninterrupted oil circulation within 912 ULS after complete oil removal due to replacement of hoses & filter.
This is what I have done:
After replacement of all oil lines/hoses & oil filter -
Partially filled (not much) new filter with fresh oil before installing
I put 2 litres of oil in the crankcase, via crankcase to tank return line (& funnel)
Put as much oil as would gravity feed down tank to pump line (may be 200 ml). Took quite a while with much massaging/squeezing of lines for all air to escape.
Put remainder of oil in tank - only just showing on dipstick.
Left to settle overnight.
(Total oil removed 3 litres)
Total oil added 3 litres
Sloooowly turned over engine - started to get "THE GIRGLE within about 6 compressions. Continued to slow turn 20 + full revolutions (each compression producing the expected flatulence).
Checked oil level in tank - just below MAX - added 100ml to make up (probably filter capacity).
I have not started engine.
Question is - have I done enough to ensure oil circulation 100% complete with no air bubbles preventing adequate lubrication to some vital part?
OR
Should I go get that pesky compressore and DO THE PURGE??
Follow up - dont have the nerve to start the engine without doing the recommended PURGE. Went & got the compressor turned down the pressure to below 15 psi. Did the purge. All good. Engine running like a "sowing machine"
