Having trouble with a water pump gasket on a Rotax 582 Blue Head with only 25 hours. I did recieve a new water pump gasket and exhaust gaskets from Wal at Bert Flood Imports under warranty however the pump gasket is still leaking, Wal did say about placing Loctite 515 on the gasket which I will try and wandering if anyone else has had this dilama. This leak on the water pump started about the 20 hour mark and progressively got worse, I have been operating in the normal operating sequence like nothing out of the norm of safe operating procedures any other help would be appreciated. Cheers.
I ended up placing some Loctite 515 on either side of the gasket and now it appears to be holding.
