Question Morgan Builds under way and completed
flyvulcan
Well-Known Member
#81
It did dazza... was the video normal speed or timelapse? Looks like you were fangin!
See post #76 from Jmbb74 for the answer about the speed on final... I suspect the vid was normal speed and it was just the aspect which gave the impression that it was a mach run.
magishme
Well-Known Member
#82
I saw that flyvulcan. I was wondering if the video was recorded with some sort of timelapse setup, albeit slight, as even with the perspective and 70 knots, it looked faster than that.
Birdseye
Well-Known Member
#83
I think it is something inherent with a number of 'action cameras', I find the same apparent speed-up effect with all videos I've taken.
#87
Hi all, I'm thinking about a project in conjunction with Garry at MAW. A Sierra Viking or Sierra 80hp Rotax combo.
Aircraft will be finished to my high standard and if you saw my plane at Evan Head recently, you'll understand.
Avionic will be standard 6 pack style, radio with ptt, dual stick, upgraded brakes (dual rudder control), lockable tinted canopy, adjustable rudder pedals, winglets, strobe Nav lights, 100lt fuel on board, leather interior, high quality paint job and a design that will turn heads.
No transponder
Finish time around June 2015, fixed price $84,000 (Viking option) TBC. Msg me if you find this of interest.
Jamie
jeffd
Well-Known Member
#88
hey jamie myself and david more so david have been keeping tabs on your build and we missed you at evans head ,where are you hoping to land next
damkia
Well-Known Member
#89
It is a well known characteristic of the wide angle lenses. It also improves the depth of field meaning minimal perception of focus changes.
The opposite happens with extreme zoom lenses (200+mm equivalent) where things appear "flat". It also makes them very touchy with the focus, in other words exactly the opposite of the wide angle lens.
#90
Hi guys I'm not sure, I'll definately be attending as many events as possible this year. Any QLD & Nth'n NSW for sure. I am going to the Southport Valentines BBQ breakfast on the 14th Feb. Alternately, anyone is welcome at Heck Field to take a look.
#91
Rigged the Sierra today probably the last time before taking it to the paint shop. Now need to have all the parts painted including all the small bits that will be put on later. We had a bit of trouble getting the engine mount right for the CAMIT motor. The alternator sticks out the back requiring some mods to the mount. I would probably try a different mount arrangement or order it with the old motor bike type coils if I had my time again. Anyhow all done now.
#96
Many thanks. My Glider has a matt black panel and I have liked that over the years. Easy to touch up.
The paint will come soon but the preparation is taking longer than I thought. I'm still fibre glassing the engine cooling ducts and fitting the spats. I haven't even started sanding and alodining it yet. Maybe early next month. It will then be moved to Taree.
#99
P5180139.JPG P5180137.JPG I have logged about 700 but its probably more like 800. Some days you just sit in the shed and do stuff. When you go to put something in the log its hard to say what you did so you don't log anything. The second build you would not have this trouble. Anyhow now its about to come back from the spray painters. I did the prep and undercoat and the spray painter did the professional stuff. Some glimpses ....
Top
