1. Hi, thanks for visiting Aircraft Pilots, the Home of Pilots, Aircraft and Aviation Enthusiasts. Please register, it's FREE to use ALL the site's great features...and this msg will disappear
  2. Please help us to give you a great mobile device method for the site. Read HERE
Rotax 912ULS rough running on ignition check
Discussion in 'General Discussion' started by clouddancer, Mar 28, 2011.
  1. clouddancer New Member
    Apr 16, 2009
    Posts
    Likes
    Trophies
    6
    0
    1
    Aircraft:
    Tecnam, Jabiru
    Have 1200 hours on 912ULS, and always did mag check at 3000, with slightly rougher running on left ignition. Now have a very harsh vibration through the airframe when doing the same check. Recently changed carby on right side (#1 and #3) due significant wear in slide and body.
    Replaced spark plugs, did all ignition tests, can swap the problem to the other ignition switch by swapping plugs on ignition systems after the modules.
    Engine runs perfectly at all power settings, but harsh vibration also present when changing throttle settings between 2600 and 2800rpm, either powering up or down.
    Engine has two blade wooden prop, carbys balanced, tried replacement coil, no change, really getting frustrated!
    Took engine out and got Wal at Bert Flood to run on test bench, no problems present, but not sitting in the aircraft might not produce the problem.
    Did have kick back starting problems about 300 hours ago, got sprague clutch replaced and new flywheel mod to improve starts, starts and runs really well.
    Any suggestions??
  2. fly_tornado Well-Known Member
    Dec 20, 2010
    Posts
    Likes
    Trophies
    1,454
    192
    91
    Aircraft:
    Drifter
    Toowoomba
    Country:
    Australia
    switch? wiring?
Share This Page
